USB DRIVER FOR IMAQ
It is an example program and here's the link:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=ED6942DF78E34659E034080020E74861&p_...
Hope this helps,
Brad
Message 41 of 197
(10,685 Views)
Dear Brad, Brooks, Helpers ...
I have a problem with USB IMAQ driver.
When I try init the camera with IMAQ USB init.vi, I get this error message: "Error -1074396024 occurred at IMAQ USB Init.vi Error system."
I do not know, what is the problem in this case.
Please help me.
I use the next component:
- Labview 7.1.1.,
- NI Vision 7.1.,
- IMAQ USB driver 1.1.0.,
- Windows XP SP2 - hungarian version.
Best Regards,
Gabor Ondi
Message Edited by Gabor Ondi on 05-09-2006 02:57 AM
Message 42 of 197
(10,652 Views)
Hi Gabor,
i don't think Hungarian is implemented already, you should read this thread top-down and post the error code you receive with the intermediate dll (it's probably the hungarion for 'show')
good luck,
Ton
My LabVIEW Ideas
Message 43 of 197
(10,646 Views)
Hi Ton,
I ran the .vi with "USB Foreign OS DLL" and I got the next messagebox (attached picture).
Gabor Ondi
Message Edited by Gabor Ondi on 05-10-2006 03:52 AM
Message 44 of 197
(10,633 Views)
Hello Brad,
I'm using an XP Pro SP2 Greek and I wonder if you could help me too.
However, after replacing the .dll, I got 4 error messages by running the Grab.vi (the one after the other).
Here they are from the first to the last in top - down order.
Thanx in advance....
Message Edited by avdel on 05-20-2006 09:00 AM
Message 45 of 197
(10,765 Views)
Here is an updated DLL with Hungarian and Greece OS support.  Let me know if there are any problems.
Brad
Message 46 of 197
(10,559 Views)
Hello Brad,
It works perfectly in  XP SP2 HUN!
Thank for your help!
Hi, Gabor Ondi.
Message 47 of 197
(10,543 Views)
Ok Brad,
Same goes for XP Pro SP2 Greek.
Everything looks fine.
I'll let you know if anything comes up.
Thank you
avdel
Message 48 of 197
(10,504 Views)
I have a problem with Windows running out of virtual memory when I run my vision application for some time.
I use USB camera driver in single shot (IMAQ USB Snap.vi)
I always close the USB sesion and Dispose Image at the end of the image out wire.
I am using Labview 8 with NI-vision 8.0.
Andrew
Message 49 of 197
(10,511 Views)
I'm having he same problem as the previous poster.  When performing multiple "snaps" and disposing of all references each itteration, the memory leaks and leaks...Only solvable by quiting labview and restarting.  Smiley Sad
Message 50 of 197
(10,453 Views)
