USB Enumeration
How do I detect USB enumeration in LabVIEW? I want to detect when a USB device has been plugged in.
Message 1 of 12
(9,747 Views)
check this
Guru
Regards
Guru (CLA)
Message 2 of 12
(9,742 Views)
Guruthilak wrote:
check this
Dear Guru,
The link you attached is showing some exception error. HTTP Web Server: Lotus Notes Exception - Entry not found in index.
I hope devcon will do what you want. Search the forum and you will get lot more information. Post back for any kinda queries.
Message 3 of 12
(9,731 Views)
Thanks mathan..
Couple of extra charaters got added to the hyperlink.. See this
Guru
Regards
Guru (CLA)
Message 4 of 12
(9,723 Views)
If you're on Windows you can also use the Windows Message Queue Library.
Message 5 of 12
(9,668 Views)
Thanks. The devcon utility will work, but it pops up a command prompt window, which is undesirable. The Window message queue library seems a bit complicated.  Actually I want to detect a USB device which enumerates as a COM port. I believe the VISA Find Resource function might work for me.
Anything wrong this this...?
Message 6 of 12
(9,637 Views)
When I tried to used this same system the output (find list) gave me the reading "ASRL3::INSTR" I believe this means COM3. Did you have the same outcome? Also, if you open up MAX (Measurement & Automation), you can communicate with your device using VISA interface.
Message Edited by ADrexelDragon on 04-12-2010 02:35 PM
CLD Certified 2014
Message 7 of 12
(9,619 Views)
Yes, for the find list I get an array of serial and parallel ports available on my PC.
Message 8 of 12
(9,607 Views)
It looks like you found out which USB port each input is.
CLD Certified 2014
Message 9 of 12
(9,564 Views)
Accepted by topic author Sidd
Sidd,
off the bottom of the command window vi is a boolean to run the window minimized.
Tay
Message 10 of 12
(9,551 Views)
