11-15-2011 08:34 AM
@Eureka wrote:
I have a request, i would like to upconvert the driver for Wayne Kerr 3260B.
The current version is for Labview 5.1 and Labview 2011 says this version is too old to convert.
I posted the same request in :
http://forums.ni.com/t5/LabVIEW/Wayne-Kerr-3260B/m-p/1774566#M616045
RTSLVU did mass compile it in LV 8.21, but LV 2011 shows error saying some files are missing.
Nothing would be accomplished by having someone else compiling the same library. The issue is that you are missing files which come from another library. This is a library that has a "_u" near the end of its name. It was common in the old days to split a library into 2 files.
11-15-2011 02:09 PM
smercurio_fc,
So, whats the solution? we dont have an updated version of this driver?
11-15-2011 02:14 PM
Who is this 'we'? You are the one who downloaded the driver from someplace. Either you did not download the entire package, did not attach it, or it was missing from the download site.
11-15-2011 04:52 PM
I downloaded the driver from the following link, its the one provided by the instrument manufacturer (Wayne Kerr):
http://www.waynekerrtest.com/global/html/products/woundcomponent/3260.htm
11-15-2011 05:18 PM
You must have done something pretty silly. The WK3260B_u.llb is part of the download. You attach it if you want it converted.
11-15-2011 05:56 PM
I have attached the file extracted from the downloaded zip file as im not able to attach zip files. There are other ".mnu" files. Do i need to attach those files as well?
11-16-2011 08:24 AM
No, the .mnu files are just for the function palette. Since you already had the other library upconverted, I only bothered to do the "_u" one.
11-16-2011 10:32 AM
Hi venkky, I'have the same problem of you.
I need to control my ITC 502 with Labview 8.2,
but the library given by OXFORD Instrument are
written in Labview 5.0.
The converted library you have now works fine?
11-16-2011 11:42 AM
Can you please upconvert the "_dr" file??? Im still getting an error message when i try to open any of the VIs...
11-16-2011 12:57 PM
That was already converted for you in the other thread! I'm certainly not going to do it again.
