Upconvert VI Requests
I need to update a VI that I found for my syringe pump.  I have no idea what version it is.  I do it need to for the 2010 version.
Thanks!
Message 1011 of 1,261
(1,325 Views)
I have this instrument driver for my Jofra dry well ATC-125a.  It is version 5 and will not open in my oldest version 8.6.  I would apreciate it if someone could save it in a newer version.
Message 1012 of 1,261
(1,301 Views)
Great idea and judging by the longevity of the thread, others think so too.
Here is my zipped package.
Don't know what the original version was, judging by error mssg, version 6.
To LV 8.2.1 as I need to run it off Vista/32
Message 1013 of 1,261
(1,298 Views)
@Chanse wrote:
Hi, I have some code for some very old insturments that was done in version 5.0 and I only have 8.5 available. There are a lot of files in the zip folder and I would appreciate it if someone could upconvert them for me. The two libraries that start with ISA may not convert because I am unsure if the block diagrams were included with them (and sadly those are the ones that I know I need). Just let me know and I will try to contact the company that made them.
Edit: Sorry, I forgot to rename some files before uploading. The code may be broken but I am not concerned about that. I just need to be able to open it.
-Chanse
Attached is the code for 8.2. Two VIs (YEHDTSC and VSL) and one LLB (270_TST) could not be upconverted because the code is actually in LabVIEW 3.1. Upconversion from that requires a toolkit from NI, so if you need those you will need to contact NI.
Message 1014 of 1,261
(1,290 Views)
Thanks!
here you go
Message 1015 of 1,261
(1,289 Views)
attached is in 8.2, which you can open
Message 1016 of 1,261
(1,288 Views)
There are no VIs in there. Just an executable. Can't upconvert an executable.
Message 1017 of 1,261
(1,287 Views)
Thanks!!!
Message 1018 of 1,261
(1,285 Views)
Thanks !
Message 1019 of 1,261
(1,270 Views)
I have a VI that was made by a colleague in LV7.1 and I need to open it in LV2010SP1.
When trying to open it I get an error:
Fatal Internal Error: "objheap.cpp", line 541
the file opens and works fine in LV7.1
I have tried to copy-paste the frontpanel/block diagram into a new file, but I then I get a diffirent error when opening the file in LV2010SP1:
LabVIEW load error code 3: Could not load front panel
All the subVI's in the file open fine in LV2010
I hope someone can convert it for me... converting to 8.# or 2009 could also help I guess
Greetings,
Bram
Message 1020 of 1,261
(1,255 Views)
