Upconvert VI Requests
Hi smercurio!
Thanks for the conversion and thanks for the additional information!!
Best regards - -Leah
Message 1001 of 1,261
(1,248 Views)
Hi I am trying to up convert this VI into a 2011 version of lab view Could someone Up convert this for me.
Message 1002 of 1,261
(1,229 Views)
Attachment Vehicle Network and DAQ Monitoring System.llb 3296 KB
Re: Upconvert VI Requests
 [ New ]
You will need someone with LabVIEW 8.2 or lesser to then open the new vi in LabVIEW 2011.  Since 8.2 is incompatible with my OS, I was unable to convert for your myself.
Ben N.
Applications Engineering
ni.com/support
Message 1003 of 1,261
(1,225 Views)
I can download 8.2 off your website and then save it in 8.2 and then it will open in 2011.
Message 1004 of 1,261
(1,223 Views)
LabVIEW 8.2 is not available for download. That library cannot be upconverted because the subVIs were saved without block diagrams. Given that it appears to have been written by VI Engineering, my guess is that there are proprietary reasons for doing so. There are also VIs in there from Traditional DAQ and that standard LabVIEW vi.lib which really should not be in the library. You will need to go back to VI Engineering to get an updated version of the program. We cannot help you.
Message 1005 of 1,261
(1,216 Views)
I want to ask for an upconvertion, I've been having a lot of problem, so I hope one of you can help me.
Source LabVIEW 4.2
Target LabVIEW 2010
Greetings
AHC
Message 1006 of 1,261
(1,214 Views)
Source LabVIEW 4.2
Target LabVIEW 2010
Greetings
AHC
ILX actually provides a LabVIEW 6 version of the 3811 driver. The other one could not be fully upconverted since a few of the VIs in the library are still in LabVIEW 3, and converting from that version requires a special tool from NI.
Message 1007 of 1,261
(1,197 Views)
Thank you!
The problem is that the 3207B is currently obsolete, I've been communicating with the technical support team from ILX but they told me that I should look for a solution because they give no more support to that device.
Do you know where can I find the "kit converter" for the LBB library?
Message 1008 of 1,261
(1,188 Views)
Hi ahc,
ask your local NI representative for the "LV3 conversion kit"...
Message 1009 of 1,261
(1,185 Views)
Hi, I have some code for some very old insturments that was done in version 5.0 and I only have 8.5 available. There are a lot of files in the zip folder and I would appreciate it if someone could upconvert them for me. The two libraries that start with ISA may not convert because I am unsure if the block diagrams were included with them (and sadly those are the ones that I know I need). Just let me know and I will try to contact the company that made them.
Edit: Sorry, I forgot to rename some files before uploading. The code may be broken but I am not concerned about that. I just need to be able to open it.
-Chanse
Message 1010 of 1,261
(1,168 Views)
