Upconvert VI Requests
@hardpig wrote:
I need these LabVIEW 5.0.1 Files upgraded to LabVIEW 2010 or 2011.
Thank you.
hardpig
Is this the same as this: http://forums.ni.com/t5/LabVIEW/convert-5-0-LLB-to-8-6/m-p/1104289/highlight/true#M487997 ?
Message 991 of 1,261
(1,162 Views)
smercurio_fc 已寫:
Yes, Thank you.
Message 992 of 1,261
(1,159 Views)
Hello, my vi is in 2011 version, I would like convertthis .vi in 2010 version.
Thank's
Chef de Projet
ERM Automatismes Industriels
Certified LabVIEW Associate developer
Message 993 of 1,261
(1,140 Views)
I need to convert a driver from 3.0 to 6.0.  Thanks in advance for your help!
Message 994 of 1,261
(1,123 Views)
Conversion from 3.0 requires a special conversion program from NI. I don't know of anyone who actually has it. You will need to contact NI to get that library converted. Have you checked in IDNET to see if there's an updated version?
Message 995 of 1,261
(1,117 Views)
Thank's
This is actually a downconvert request. In the future please post requests related to going from a higher level version down to a lower version in the Downconvert Requests Thread.
Message 996 of 1,261
(1,115 Views)
Ok, I'm sorry.
Thank's for the downconvert.
Chef de Projet
Message 997 of 1,261
(1,106 Views)
Actually you were a big help as I had posted both a 3.0 and 8.0 version for conversion.  You were able to convert the 8.0 for use in 6.0 successfully.
I had contacted NI about the conversion program but all they seemed to want to do is sell me new software.  I am writing a simple program to control three instruments so there was not need to upgrade.  Thanks for your help again.
Message 998 of 1,261
(1,097 Views)
Can you please convert these vi's from LV5 to LV 2010?  Thanks! - -Leah
Message 999 of 1,261
(1,085 Views)
attached.
WARNING: The library contained within it VIs that are part of traditional DAQ. These should be removed from the library, and you should install Traditional DAQ on the target machine. It also contains numerous VIs that are part of vi.lib. These should also be removed from the library and replaced with the ones that ship with LabVIEW.
Message 1000 of 1,261
(1,082 Views)
