Upconvert VI Requests
@FraBaggio1 wrote:
Can someone convert all the Labview 5.1 llb and vi files of the folder to labview 2011 please?
source LabVIEW version: 5.1
target LabVIEW version: 11
Log files can't be upconverted.
Message 1181 of 1,261
(1,307 Views)
@Nivs wrote:
Hi all,
I am using the LeCroy Wavepro Oscilloscope and the only Labview driver i could get for this instrument is of Labview version 5.1
It would be of great help if someone can upconvert the 5.1 Version to Labview 8.5.1 Version.
Thanks in advance
attached as 8.2
Message 1182 of 1,261
(1,306 Views)
Thanks a lot! Now I can open properly some files, but there are some that I cannot open. I explain you better. For example if I try to open the file "bfield" in the folder "Cryogenic software" it starts downloading and it opens a window where it asks me to find a VI named "SMS set ramp rate" and if I ignored it asks me for others until that it opens the front panel, but with a bad run arrow. What does it mean?
Thanks a lot!
Message 1183 of 1,261
(1,297 Views)
Why do you select ignore instead of pointing to the llb with the VI? Clicking on ignore means to not load the subVI so obviously the VI you are trying to open is going to be broken.
Message 1184 of 1,261
(1,293 Views)
Thanks a ton.... that worked great 🙂
Message 1185 of 1,261
(1,288 Views)
Can anybody please convert the attached VIs?
 original v5.1
 target  v8.5
Yaowei
Message 1186 of 1,261
(1,280 Views)
Could I get the following 2010 project converted to 6.0 Project
Thanks!
source LabVIEW version 2010
target LabVIEW version 6.0
Message 1187 of 1,261
(1,267 Views)
Thanks!
This thread is for UPconversions. Going UP in LabVIEW versions. You're asking for a DOWNconversion. Going DOWN in LabVIEW version. Downconvert Requests Thread
Aside, talking to myself: There's a lot of people making this same mistake. Why is the concept of DOWN and UP so hard to understand? Or is that people just don't read?
Message 1188 of 1,261
(1,256 Views)
 original v5.1
 target  v8.5
Yaowei
Attached as 8.2
Message 1189 of 1,261
(1,255 Views)
Can some one please help me to upconvert the attached .llb file please?
Thank you.
source version: 5.1
target version: 8.5.1
Message 1190 of 1,261
(1,242 Views)
