Upconvert VI Requests
Message 71 of 1,261
(3,910 Views)
Does anyone can help me convert R&S SMHU driver LabView 5 to LabView 8.5?
Souce LabView version : 5
Target LabView version: 8.5
I appreciated your help.
Message 72 of 1,261
(3,887 Views)
Hi tjeff,
here we go.
Mike
Message 73 of 1,261
(3,882 Views)
hellow.
Help me to convert this Lv4 to Lv 8.6
Message 74 of 1,261
(3,871 Views)
Hi Ramsgt,
it's for 8.6 now.
Mike
Message 75 of 1,261
(3,863 Views)
This is a nice idea but all receiver must be aware that there are a lot of pitfalls just converting the VIs.
Each LV version has its own upgrade chapter in the user guide and not all things are mentioned there.
One of the critical things is this one mentioned here: http://forums.ni.com/ni/board/message?board.id=BreakPoint&view=by_date_ascending&message.id=12323#M1...
There should be an old discussion here about a change in handling tunnels in for loops when the loop will run 0 times. Older LV versions gave the value back in the output tunnel which was put in in the input tunnel. In LV 6.1 or 7.0 this behaviour change. If you have code where the number of iterations depends on array size or string length and you have a through going wire your code will behave not correct any more in the case the array is empty or the string length is zero.
All receivers must be aware that they have to test  the code thoroughly.
Message Edited by waldemar.hersacher on 05-06-2010 10:15 PM
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 76 of 1,261
(3,832 Views)
The for loop behaviour was changed with LV 6.1. I found it here: http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=38667#M38667
Waldemar
Message 77 of 1,261
(3,827 Views)
Hi waldemar,
that's something a assume. Converting is no guarantee for getting running code.
Mike
Message Edited by MikeS81 on 05-07-2010 12:50 PM
Message 78 of 1,261
(3,809 Views)
Could anyone please convert the following Vi's from Labview version 5.1 to 7.1 please?
Thank you!
-Carol
Message 79 of 1,261
(3,767 Views)
Thank you!
-Carol
You can't. The VIs were saved without a block diagram, so LabVIEW has no "source code" to recompile. You need to go to where you got the VIs and get the original VIs, or have whoever gave them to you re-give them with the block diagram.
Message 80 of 1,261
(3,762 Views)
