Upconvert VI Requests
Ops, that is true.
I attached the Vi's now with block diagrams. I believe the two last files are already in labview 7.1.
So I just need the first Vi from 5.1 to 7.1.
Thank you again
-Carol
Message 81 of 1,261
(3,679 Views)
Hi Carolg,
here it is... And please clean up all those locals and sequence structures!
Message Edited by GerdW on 05-10-2010 08:07 PM
Message 82 of 1,261
(3,669 Views)
please could any one help me to convert this 5.0 file to labview 9
Message 83 of 1,261
(3,627 Views)
Attached is in 8.2. It's a badly written VI.
Message 84 of 1,261
(3,612 Views)
There is an example on the Developer Zone: Programmatically Inserting a Step into a TestStand Sequence Using LabVIEW
Please convert:
FROM LabVIEW 5.1.1
TO   LabVIEW 9.0.1
Thanks!
Message Edited by LVB on 05-19-2010 12:54 PM
CLA, CTA
Message 85 of 1,261
(3,592 Views)
Hi LVB,
do you think LV9 will still use the very same functions/parameters?
But hey, here you go with LV7.1 version...
Message 86 of 1,261
(3,586 Views)
Can anybody help me convert the attached codes?
source LabVIEW version: 5.1.1
target LabVIEW version: 8.6.1
Thanks a lot!
Message 87 of 1,261
(3,515 Views)
Attached is the code in 8.2, which you can open in 8.6. I am assuming you have the GCSTranslator DLL that's used by many of the subVIs.
Message 88 of 1,261
(3,508 Views)
Yes, I have. The codes are working well in 8.6.1. Thank you very much for your quick response!
Message 89 of 1,261
(3,497 Views)
Is it possible for this .llb to be converted from 5.1 to 9
thanks in advance
Robin
Message 90 of 1,261
(3,474 Views)
