Update string indicator from a sub-VI
Hi everybody,
This is my first post here, I always found the answers I needed here before.
My problem is that I need to update a string indicator (which is in my main VI) from a sub-VI but before the end of this sub-VI. This update depends of what the user wants to do in the sub-VI, perform or not the homing of a motor.
One solution would be to ask the question before calling the sub-VI but I prefer to have everything in the same Sub-VI.
Thank you guys
Message 1 of 9
(7,765 Views)
Accepted by remvu
Its simple,Find the attached VI
Message Edited by Baji on 07-21-2009 02:59 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 9
(7,762 Views)
Hi Baji,
Thank for your answer, but how do you create the String refnum in the sub-VI ?
EDIT :
It is ok I have found that.
Thanks !
Message Edité par remvu le 07-21-2009 04:49 AM
Message 3 of 9
(7,747 Views)
You can easily create this by right clicking on the output of your Reference of the string control in the Main VI and selecting Create Control,use the created control inside the SUB vi.
Message Edited by Baji on 07-21-2009 03:26 PM
Balaji PK (CLA)
Message 4 of 9
(7,741 Views)
Thanks again this is easier than created a refnum ctl and then "select VI Server Class" 🙂
Message 5 of 9
(7,718 Views)
Or you could drag and drop a control over the reference.
Ton
My LabVIEW Ideas
Message 6 of 9
(7,709 Views)
Or you could attend a Labview Basics 2 Course. It is quite helpfull, lasts 2 whole days and spares 2 months selftraining. If you have a look at the content of the course, property nodes used for updating your front panel values is handled for instance, and a lot more of course.
Best Regards,
Laurent
Message 7 of 9
(7,689 Views)
Best Regards,
Laurent
Hi Laurent,
what is the content of this post?
If NI starts adding such a post for every 'semi-advanced' level at the forums, the forums will be flooded. I assume that NI can get the contact details of every member and call/mail directly with such a user.
Ton
My LabVIEW Ideas
Message 8 of 9
(7,668 Views)
no...noo..  NoooooOhhhh!!!!
You would not want more telemarketers calling more people for whatever reason.
There's been WAYYYYY too much abuse with phone calls.
I saw that post as being similar to us posting that they should do on-line training, etc..
Like:
"To learn more about LabVIEW, I suggest you try looking at some of these tutorials. "
Message 9 of 9
(7,599 Views)
