Value of Color box
 Hi, what is the relation between the value that coming out from color box and the color selected in Front panel as in the attached image ?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(7,397 Views)
Hi dhans,
A color in LabVIEW is a representation of a 32-bit integer. You can separate the 32-bit integer into four U8 integers:
  • Transparency, where 0 is solid and 1 is transparent. Please note that most color boxes will not accept a transparent input - you will need to keep this first integer as 0 to result in a valid color.
  • Red (any integer from 0 to 255)
  • Green (any integer from 0 to 255)
  • Blue (any integer from 0 to 255)
If you wish , refer the following link for more details.
http://digital.ni.com/public.nsf/allkb/B61D723CC7B7BE4E862568F8004C3ACB
Regards
Deepu Jacob
Waiting For the inner calling 🙂
(7,383 Views)
Hi djac91,
   Thanks for the reply. The link you have given helps me to undertsand about colors used in labview. But still one point i need to understand further. In  the attached image irrelevant value( I think) is flowing from color box to the variant node. Thats what i am asking for. Relation of that  data to the color i have chosen.
Best Regards,
Dhans 😉
Kudos are welcome 😉
(7,353 Views)
The value you are getting is 46253 (decimal), just convert it to Hex format and you get 00B4AD which is six digit Hexadecimal representation of RGB Values.
-Like first two digits representing Hex value of R and next two digits to G and last two to Blue.
uday
(7,332 Views)
Accepted by dhans
The value is relevant. Check the attached vi.
(7,328 Views)
Thanks to both of you!!!Smiley Happy
Best Regards,
Dhans 😉
Kudos are welcome 😉
(7,316 Views)
