Waveform graph - Number of major ticks on x scale
Hello all!
I'm trying to display meteorological measurements throughout a day in a minute resolution. For that purpose I'm using a Waveform Chart with fixed length on x-axis (0-1440). However, major ticks are distributed by 100, i.e. 0, 100, 200, 300, ..., 1400, 1440. How can I distribute these points by 60, so that I can put hour labels 00:00, 01:00, 02:00 etc.
Thanks!
Marko.
Message 1 of 17
(9,024 Views)
You should be able to click on the label for 100 (this first to the right of the 0) and just change it to 60.
Message 2 of 17
(8,998 Views)
Accepted by topic author mgulin
You can use a Property Node to set the Increment property of the graph.
To create the property node on the Block Diagram: right-click on the graph, select Create >> Property Node >> X Scale >> Range >> Increment. Place the Property Node on the block diagram. Right-click on the Property Node, select Change to Write. Then you can wire a numeric constant of '60' into the Property Node.
Note: the the graph must be wide enough to support the number of tick marks. Otherwise the property node will change nothing.
Taylor B.
Message 3 of 17
(8,976 Views)
Thanks guys, this works!
Marko.
Message 4 of 17
(8,939 Views)
I am not able to understand this because i have also used the increment for this but i am not getting the same result
Message 5 of 17
(8,598 Views)
In what way is the result different? Please attach your VI so we can see what is going on.
Message 6 of 17
(8,569 Views)
Did you notice: "Note: the the graph must be wide enough to support the number of tick marks. Otherwise the property node will change nothing."
If the size of your graph is too small to display the increment, then it uses the default increment. This is also explained here: KnowledgeBase: Unable to Change XY Graph Axis Increment to a Fractional Value.
If this is the issue, then manually resizing the graph should fix it.
If this is not the issue you are seeing, then I agree that you should attach your VI.
Taylor B.
Message 7 of 17
(8,554 Views)
i want to change the x axis as it should appear like 2:20 2:40 in this manner for the 24 hours how can i do it
Message 8 of 17
(8,521 Views)
This can be done in Graph Properties under display format
Ken
Message 9 of 17
(8,493 Views)
BUt i want that major tick should have 20 minutes gap  my data should display like 8:00 8:20 8:40 9:00 for 24 hours how can i do that and moreover the graph or chart should be moving
Message 10 of 17
(8,459 Views)
