Why do some AVI formats not work properly with IMAQ?
Sorry, still can't open your code. I understand you, maybe it is really codec issue, i am not sure. NI also integrate this code to DLL file, we can't find out how it work.
Colin Zhang
LV7.1/8.2/8.2.1/8.5/8.6/9.0/2010/2011/2013/2015/2016/2020; test system development; FPGA; PCB layout; circuit design...
Please Mark the solution as accepted if your problem is solved and donate kudoes
Home--colinzhang.net: My Blog
iTestGroup: One-step test solution provider!
ONTAP.LTD : PCBA test solution provider!
Message 11 of 15
(2,521 Views)
I've tried saving the project as a compatable file type again. I don't suppose you happen to have any idea of the difference between the two AVI files I uploaded?
Message 12 of 15
(2,512 Views)
Accepted by Austin55
ooh, yes, should be the different codec. It is really different. Thank you, let me know more.
http://www.ni.com/white-paper/14466/en/
Colin Zhang
Message 13 of 15
(2,503 Views)
Thank you very much! I didn't realize I had to do more than convert it into an AVI format. I changed the video format to MJPEG and it now works fine.
To anyone trying to solve this problem, I was using MediaCoder, but there are other freeware programs avalible. There are a few options here: http://www.ehow.com/how_7255268_convert-avi-codecs.html
Message 14 of 15
(2,490 Views)
AVI is just a container format. The video and sound streams in it can be coded in many different formats, each of them needing its apropriate codec installed on your machine.
While NI-IMAQ is indeed provided as compiled shared library (DLL), the actual code responsible to deal with your AVI files is Microsoft DirectX which IMAQ provides just a wrapper to better integrate with the LabVIEW system. There is nothing you could learn from looking at the NI IMAQ portion of that code as to why it works with one AVI file and not with the other, as all the relevant handling is really done in Microsoft DirectX. And that code is not accessible either except through special Microsoft shared source code licenses with very restrictive conditions. Even then the actual handling of the various stream formats is all done by dynamically loading the appropriate codec component DLL which can be from many different sources and doesn't have to necesseraly come from Microsoft at all.
Rolf Kalbermatter  My Blog
Message 15 of 15
(2,476 Views)
