Why is For/While loop Iteration I32?
Thanks a lot.
Now,i have made the final program which can do amplitude-scaling,time shifting and time-scaling as well.I have used a kind of bottom-up approach.As of now i have used all elementary functions but i wanted to simplify it further by either reducing blocks or something else that you may suggest.
Message 31 of 38
(1,858 Views)
Look at the functions in the Numeric palette.
There is a "negate" function (-x) that you can use instead of multiplying by a -1.
There is a "reciprocal" function 1/x that you can use instead of literally taking 1 and dividing by your value.
Message 32 of 38
(1,843 Views)
Actually, I'd like to go a bit further down the path RavensFan started you on.
For those of you without a viewable copy here is the "Code of current discourse":
A ctrl+U and some alignment from the source were taken.
Some might ask why go and mess with this "Working" Code.   Primarially "Why equalls em ex plus bee"  but there are a few other nasty things going on that could make you think.  (Although, modern LabVIEW compilers are forgiving)  so let me re-write that snipette.
I doubt HIGHLY that this is what you want!  but simplifying your code to migrate loop invarient calculations and resolve tautologies yields this snip:
Message 33 of 38
(1,831 Views)
Jeff·Þ·Bohrer wrote:
That express VI just needs to go!
Here's what I would probably do... 😉 (not fully verified for correct operation)
Message 34 of 38
(1,814 Views)
I knew there was more availableSmiley Very Happy
(No surprise to me who found some.) although there is something still there (Sign[B] didn't really work and Christian might be closer with his code but 1x^[0,1]=[1,1]  so Re = 0 as a constant?
Did CA just code a bug?
Message 35 of 38
(1,807 Views)
I was just waiting for somebody to put out the Ramp function.  I just didn't want to go there yet with the OP.
Message 36 of 38
(1,806 Views)
I coded  [0|1] x 2^1 = [0|2] (multiplications/divisions by integer powers of 2 are just bit shifts, which are very efficient. :D)
Message 37 of 38
(1,791 Views)
I suspected that I read that wrong
Message 38 of 38
(1,777 Views)
