Wrap in to string Indicator
Is there any property to update string like this when an array of different value comes? I need to keep on updating the string continuously.
Message 1 of 22
(5,341 Views)
You are not providing enough information. What is the relation between the array and the string?
What I see in you picture is a String control (not an indicator, I guess). If you want to update the string programatically and not interactively, an indicator should be more suitable. To update a control, you can use a Local Variable or a Value property node (the property node can be used in another vi passing a reference of the indicator to that vi). To update an indicator, you can simply use its Terminal on the Block Diagram, too.
Paolo
Message 2 of 22
(5,320 Views)
Generate a user event when you send a new string. Failing that, remember the old array and compare it so you notice when a new one appears.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 22
(5,303 Views)
Sorry for the insufficient information. I hope the below image can explain you more about this. Updating to string is not a matter, but wrapping the string like below mentioned picture is my required thing.
The above mentioned picture is just for an example. But my string should look this.
Message 4 of 22
(5,290 Views)
And use a local variable instead of property node to update the value for best performance. If there are many updates per second, consider updating the indicator only as often as the UI needs to update.
(edit: did not see previous post before posting this)
Certified LabVIEW Architect
Message 5 of 22
(5,284 Views)
Hi, please understand that, updating to string is not a matter. But, how the string looks, that's only my concern.
Message 6 of 22
(5,281 Views)
Hi Alwin,
Use SearchAndReplaceString on the result of ArrayToSpreadsheetString and replace all linefeeds by spaces!
ArrayToSpreadsheetString will always place linefeeds between rows of a 2D array…
Message 7 of 22
(5,271 Views)
I hope you meant this. If it is, it doesn't meet my requirement.
Message 8 of 22
(5,261 Views)
Accepted by Alwin_Capsys
Replace linefeeds AND carriage returns
Paolo
Message 9 of 22
(5,249 Views)
We can only guess your requirements when you do not provide the VI. From the picture, I guess you want four spaces instead of EOL, so do:
Message 10 of 22
(5,247 Views)
