Writing to a cell in an existing Excel file without prompt of overwriting
I am trying to learn communicating with Excel spreadsheet via ActiveX. I started with the Labview example "Write Table to XL", however, this example creates new file which is not my case of overwriting an existing Excel spreadsheet. So, I made my changes to the VI to overwrite an existing file with my new value. Unfortunately, there is always prompt of overwriting the file, and even though I press "yes", the file keeps unchanged.
The help I need is to kindly :
1- check my attached VI for any mistakes
2- make the VI overwriting the file without any prompts
Thanks in advance
Message 1 of 13
(7,085 Views)
Can you save it in LV2009?
Ben64
Message 2 of 13
(7,059 Views)
Sure, and thanks for your help.
Message 3 of 13
(7,047 Views)
You need to also include the subvi you modified.
Ben64
Message 4 of 13
(7,045 Views)
(Didn't had enough time to complete the edit)
You are using the OpenBook vi from the Write Table to XL exemple. Since you didn't include the modified Open Book subVI my guess is that you are connecting your file path to the template input of the add method, that is probably why you can't save the changes. This vi is used to add a new workbook to the workbooks collection (it uses the add method). To open an existing workbook you need to use the workbook open method. Then you can pass this reference to the open sheet vi
Ben64
Message 5 of 13
(7,042 Views)
I really appreciate your help, but I already changed the configuration to open a file path taking another ActiveX example as a reference. Here is my subVI's I used, but they are merged in LLB. I am sorry for my ignorance of how to extract all the subVI's from this file.
Message 6 of 13
(7,031 Views)
I have tried to save each subVI in a new location and I got all of them separately. Hope they work, since I don't know how to check their compatibility for previous versions.
Message 7 of 13
(7,029 Views)
Accepted by Diaa Abidou
In your Open New Workbook.vi you have a Open/Create/Replace File.vi. You don't need that.
Message 8 of 13
(7,012 Views)
Thanks for your help, it works fine.
I would be grateful if you put links for learning the alternative ways of communicating with Excel instead of ActiveX such as ADO, since I tried to learn these ways but I didn't found clear instructive resources (i.e. tutorials, examples).
Message 9 of 13
(7,002 Views)
Do you even understand what you are asking?
ADO = ActiveX Data Objects
Message 10 of 13
(6,996 Views)
