XYZ array to intensisty map
@M_Ricci wrote:
"...find a way to turn the original points into a set of triangles directly."
This is a very interesting suggestion, I will work on.
You can probably create a triangular mesh (start reading here) for all existing XY points while initially ignoring Z, then add the actual z as a last step.
LabVIEW even includes a tool for points in a plane. Try it!
Message 11 of 32
(419 Views)
Here's a quick example:
Message 12 of 32
(407 Views)
Dear Altenbach,
your support and solutions are very helpful.
I am going to study all your new suggestions.
Max
Message 13 of 32
(378 Views)
The original dimension is visible in min and max values (red dots in "3D points" graph).
Changing the number of samples it changes also the original dimension.
For example, in test2.vi now samples= 200 and "3D Intensity map" or "waveform graph" are both 200.
Modifying samples both graphs follow this number.
Is it possible to modify samples maintaining always the original dimension in "3D Intensity map" or "waveform graph"?
Message 14 of 32
(353 Views)
You can change the multiplier of the x and y axes. By default, the markers correspond to the array index, but you can apply any other scaling.
Message 15 of 32
(345 Views)
Here's how that would look like (simplified). (I am not sure how you messed up the z scale)
Message 16 of 32
(341 Views)
The problem is that with samples= 400, the result is image A.
With samples= 50, the result is image B.
I found it is not related to the graph scale, pheraps in Graph2 it is more clear what happens changing samples:
Z remains the same (144.06) while XY changes.
While XY extremes must have always the same value of "Interpolate 2D Scattered" Xi or Yi extremes.
Message 17 of 32
(300 Views)
... and they do. You don't show how you generate the grey 3D surfaces, but X and Y must of course be based on the ramp, not on array indices.
I don't understand why are you still messing with the scattered interpolation instead of the triangular mesh.
Message 18 of 32
(295 Views)
Hi Altenbach,
3D surfaces are generated using the Intensisty MAP.vi in my first message and then opened by an external software.
Anyway attached there is a unique .vi that creates the 3D file and then opening it directly (following described points to check differences).
I don't know at the moment how to work with triangular mesh, so I am trying to fix a method, to understand better, and then switching to a new one.
Message 19 of 32
(267 Views)
The stl file is just a list of triangles and after adding the z dimension, you can just write the Delaunay triangles generated as shown earlier, right? Creating triangles from a rectangular mesh seems like a giant detour!
Message 20 of 32
(258 Views)
