XYZ array to intensisty map
Here's how to use the original points to create the STL file. Seems trivially simple.
(and please don't use a greedy loop to waste 100% of a CPU core doing nothing until stop is pressed, see also)
Message 21 of 32
(433 Views)
Great Altenbach!
It works very well, thank you!
The last point: the process creates a closed surface (see image A), probably because in the last loops it creates triangulations (see image B and zoom B2).
Is it possible to try avoiding triangulation on this side, in order to open the surface?
Message 22 of 32
(408 Views)
You can filter out any triangles that you don't want, of course. (In this case, you could filter any triangles where all three vertices have the same specific Z value.)
You posted in a pretty old version (2013). What is your actual LabVIEW version?
Message 23 of 32
(403 Views)
Accepted by topic author M_Ricci
Assuming your LabVIEW version has the conditional output tunnel, here's all you need to do. Try it!
(slightly simpler logic is possible, but harder to read)
Message 24 of 32
(397 Views)
Perfect, thank you Altenbach for your huge support!
Max
Message 25 of 32
(366 Views)
One alternative (checking it at least one is different)...
Message 26 of 32
(344 Views)
On a side note, this entire method only works for a planar arrangement in x and y, i.e. if there are no multiple planes (e.g. a sphere or a donut, etc.). A more general solutions for points in 3D would involve more code (see here).
Message 27 of 32
(317 Views)
Dear Altenbach,
I have seen d-dimensional Delaunay is not available in Labview, is there a method to work with 3D points in multiplanes like a sphere or a donut?
Message 28 of 32
(242 Views)
@M_Ricci wrote:
Dear Altenbach,
I am sure there is. You can look at the 2D LabVIEW code for some ideas (it is just a VI with exposed code!), then expand it to higher dimensions. I have not tried. Good luck!
Message 29 of 32
(220 Views)
@M_Ricci wrote:
Dear Altenbach,
it looks like there is a "hacky" 3d version...
https://forums.ni.com/t5/LabVIEW/Delaunay-triangulation-and-mesh-generation-in-3D/m-p/1307044#M53772...
at least,  VertArray from "create mesh.vi"  accepts XYZ choordinates
Message 30 of 32
(193 Views)
