XYZ array to intensisty map
In TrianglestoSTL_2.vi there is a button to switch between the two Delaunay triangulations:
native Labview:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/vi-lib/analysis/geometry-llb/delaunay-tria...
and the link:
https://forums.ni.com/t5/LabVIEW/Delaunay-triangulation-and-mesh-generation-in-3D/m-p/1307044#M53772...
The last one is faster, but the final result is the same.
In this case they seems not able to create a good 3D triangulation. it's more complex than I thought.
Message 31 of 32
(57 Views)
Original points are sorted by z coordinates, while both Delaunay triangulations operate a sort of points in order of ascending xy coordinates.
Could it be a cause of points confusion?
Message 32 of 32
(47 Views)
