abnormal motor noise analysis
Task: To analyze gear condition in running motor using PCI 4474
What would be the best way to differentiate between smooth operation and an abnormal sound? Any help would be appreciated.
(3,269 Views)
"JHP" wrote in message
news:50650000000800000027FF0000-1079395200000@exchange.ni.com...
We were doing this about 25 years ago on rear axles using a spectrum
analyzer, if I remember correctly. There may be an SAE paper out there that
will give you some ideas...
(3,269 Views)
I also did something like this 20+ years ago. We looked at the spectrum of several sets of good gearboxes and several sets of bad ones. Once we determined the differences we developed an instrument with filters for the significant frequency bands. We actually had three different problems we could detect (bad bearings, gear tooth misalignment, and burr or gouge on a tooth). Each produced a different sound.
Lynn
(3,269 Views)
JHP,
As the other posts indicated, the answer to your question is really going to depend on the specific application that you are working on.
However, if you want to learn a bit more about machince condition monitorig, there are some resources available here on the website. These can be found here:
Machine Condition Monitoring PowerPoint Presentation
Order Analysis for Machine Monitoring and NVH Interactive Tutorial
I hope those documents help. Best of luck with your application.
Jed R.
Applic
ations Engineer
(3,269 Views)
