agilent current source can not reach higher voltage
hi i have an agilent B2901A current source and im trying to out put 100V... since its capable to about 200V but i can go abouve 21V. When i enter anything about 21V it only sends out 21V. Anyine know how to fix this. Is it my compliance values or range?
Thanks in advance
Message 1 of 10
(3,899 Views)
What current is it putting out @ 21V with your circuit?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
Message 2 of 10
(3,895 Views)
about 21mA... its set up with a aproximate 1kohm resistor
Message 3 of 10
(3,880 Views)
Are you using two channels?  Looking at the data sheet for the instrument it appears you can't use more than 21V if using 2 channels.  I haven't looked at the manual for it so I could be wrong.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 4 of 10
(3,861 Views)
If you are set up as a constant current source, then you should be putting out 21V (21mA*1kOhm = 21V).  Looks like it is working exactly as it was designed.
If you truely want 100V out, then you need to change it to a constant voltage source and increase your compliance current to at least 100mA.
GCentral
Message 5 of 10
(3,856 Views)
no just 1 channel.
Message 6 of 10
(3,799 Views)
i believe i do have it set up as a constant voltage source and even when i do it manually and not through labview i can not seem to go above 21V even witht the complaince surrent at 100mA or higher?
Message 7 of 10
(3,797 Views)
If you can't do it manually, then you don't have a LabVIEW problem. You need agilent tech support.
Message 8 of 10
(3,795 Views)
so i got it so i can go higher manually but i cant go as high through labview as i was manually... the higherst i got manually was 42V with 100mA limit
Message 9 of 10
(3,780 Views)
Accepted by adgurrol
ok nvm i figured it out thanks for all your help it turns out if i want to go above 42V i need an interlock terminal. the problem through labview was mu limit compliance was too high.
Message 10 of 10
(3,777 Views)
