array
I want to display 2 arrays (3X3 elements) from a list of 12 arrays created in labview. I've defined those 12 arrays and now I want to use a While Loop to display 2 of them (I've named them with numbers from 1 to 12 and I want to have the possibility to select which two arrays to display).
I hope you can understand my explanation of what I want to do, this is a first part of a project, but I'm new in Labview so if you could help me with some suggestion it will be great.
Thank you and  I apologize for mistakes, but English is not my native language
(4,774 Views)
Accepted by MP21
If the arrays are the same size, then make a 3D array and then you just use Array Index to get the page you want.
(4,763 Views)
Thank you! I will try to do like you suggested.  I managed to do using CASE Function, but I think your idea is better.
(4,707 Views)
I tried to create a 3D array, but i don't know how to use the third dimension of the array. As I said in the first post, I have twelve arrays (3X3 elements), and i want to display two of them. I've done that with a case structure (I put that case structure in a subVI to not be so charged the  block diagram). If you could help with a suggestion of how i could put those arrays in a 3D array it will b great.
I'll post the block diagram and the front panel for the case structure.
Thank you!
(4,579 Views)
1. Use Build Array to combine all of your 2D arrays into a 3D array.
2. Use Array Index to get the page you want.
(4,567 Views)
An example of using the build array function:
You can find many tips and resources here:
http://www.ni.com/getting-started/labview-basics/
(4,563 Views)
