05-11-2006 10:39 AM
05-11-2006
05:38 PM
- last edited on
11-10-2025
05:00 PM
by
Content Cleaner
Hi Kevin.
First of all, I am sure you know the document LabVIEW and Hyperthreading.
I have a PC with two CPUs (P3, each 1000MHz, this should be close to your 5 years old PC) and at the same time I am working with a ~3 years old hyperthreaded P4 2,8GHz. Both PCs are no longer state of the art. But the P4 is between 1 and 10 times faster, and he is especially better in computational algorithms like image processing (For example: Edge Detections run about three times faster on the P4).
There is a good chance, that an up-to-date PC will be fast enough for your demands. I recommend, that you run a benchmark of your software's most important parts on a hyperthreaded or dual-core PC. Verify, that the software in fact (or should I say: without modification) uses both CPUs and make an estimation, how much spare time you might have. (As you can take from my words: I expect that a new PC will run your job in less than seven seconds.)
I hope this was helpful, Guenter
05-12-2006 02:48 AM
Thanks Guenter,
Somewhat embarrassingly I had not seen the link before so I will read that! Thanks for your other comments also.
Regards
Kevin
