Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
can't understand how to use the integral function
5167
Member
09-18-2003
09:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I just can gv the signal to the integral VI.Thus , how it know my time interval?
0
Kudos
Message
1
of 4
(3,106 Views)
Reply
Re: can't understand how to use the integral function
altenbach
Knight of NI
09-19-2003
09:05 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
There are several integral functions (numeric Integration, Integral x(t), Integral x(t) PtbyPt) and all let you specify "dt" as input.
You need to wire this, so the VI knows the time interval. If you leave it disconnected, it is assumed to be 1.
LabVIEW Champion
0
Kudos
Message
2
of 4
(3,106 Views)
Reply
5167
Member
Author
09-24-2003
01:52 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sorry,ican not understand u answer.i just can wire the signal only.The signal is data rght?Then how to let the Subvi know that the time interval?
0
Kudos
Message
3
of 4
(3,106 Views)
Reply
altenbach
Knight of NI
09-24-2003
09:52 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Could you attach a real example?
The integrations I typically use all provide a dt input (see image).
LabVIEW Champion
Integrations.gif 2 KB
0
Kudos
Message
4
of 4
(3,106 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
