catch event when digital signal DAQ input has falling edge
I am using NI ELVIS II device, I have a digital input signal. I want to catch the event when this input signal changes from HIGH to LOW, I don't care how many counts. To do this, I used a local variable (as in VI attached) but I think it is still not the most optimal. Do you have any other way to replace my plan and speed up it? Thank you.
Message 1 of 13
(4,509 Views)
Hi hung,
using local variables in a loop is NEVER a good idea!
What about using shift registers instead?
What about that (classic!) Rube-Goldberg in your VI?
IF true THEN true ELSE false
That is basically a NOP…
When your loop runs endlessly, then those DAQmxStopTask and DAQmxClearTask will never be called…
Yes, sure!
Use the DI signal as a trigger for the second task. Start the second task on a falling edge of the first DI signal…
To learn about that DAQmx feature you should look at the example VIs in the example finder, coming with LabVIEW!
Message 2 of 13
(4,486 Views)
Hi GerdW,
Thank you for the things you said very interesting. The algorithm that uses local variables as I did before is due to thinking like the previous C/Arduino programming language I used. As you said, Use the DI signal as a trigger for the second task. I tried searching for example
I don't know if this is an example you want me to find.
Message 3 of 13
(4,480 Views)
Hi hung,
please see the example "Analog Input - Synchronization": there is a StartTrigger at the 2nd DAQmx task.
You need to do the same with your DI task: set the first DI signal as a start trigger - you can even select the edge of the DI pulse…
Message 4 of 13
(4,474 Views)
Hi GerdW,
I tried trying to read the example and look for more examples online. But in the example "Analog Input - Synchronization" I don't understand how it works.
I found an example on google but also could not understand how it works. Can you help me make a simpler example? I have been studying labview for 2 days, I see examples that are too difficult. Thanks you!
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PBVSA2&l=en-VN&fbclid=IwAR1Ixs3bRPCi...
Message 5 of 13
(4,456 Views)
Hi GerdW,
I just wrote an example, you can help me see if it works properly: "when the Master Channel has an  Input pulse from high to low, the Slave Channel has an output pulse from a low level to a high level." Thank you.
Message 6 of 13
(4,450 Views)
Hi hung,
you don't need that "master" task.
All you need is to set the correct (PFI) channel for this DAQmxTrigger…
That's why there is a "Training" section in the header of thisLabVIEW board.
You really should take that!
You want to cope with DAQ hardware, so you better do some training before starting to code…
Message 7 of 13
(4,440 Views)
 I have a NI-ELVIS II device. I want to read an input analog signal when there is a digital input signal from a high level to a low level. I use DAQmx Triggers to do that. Analog signal my input connected to AI0 + -, digital input signal connected to FPI0. But I can't read anything, can someone help me? Thank you.
Message 8 of 13
(4,434 Views)
 I have a NI-ELVIS II device. I want to read an input analog signal when there is a digital input signal from a high level to a low level. I use DAQmx Triggers to do that. My Analog signal input connected to AI0 + -, digital input signal connected to FPI0. But I can't read anything, can someone help me? Thank you.
Message 9 of 13
(4,429 Views)
Hi hung,
why did you create two more threads for the very same topic? Please keep discussions in one place (for one problem)!
- You didn't set any trigger source, the DAQmx channel control is empty.
- You set the edge to "rising", but from your description you want to wait for a "falling" edge.
- You didn't set any number of samples to read.
- You set the acquisition mode to "continuous" (which is fine), but only call DAQmxRead once. IMHO there should be a loop around DAQmxRead.)
- Do you get any DAQmx errors? If yes: which one?
- Did you connect your digital signal to PFI0?
Message 10 of 13
(4,418 Views)
