compare cluster that contains clusters
I want to compare two clusters (the clusters are type def and each cluster contain many clusters).
How can i compare them and return array or clusters of boolians for each "sub-cluster" in the original one?
(The compare elements mode also compares the controls inside each panel)
Message 1 of 10
(6,105 Views)
I guess I don't understand the question. The comparison will result in the same structure and you can unbundle the inner comparison result any way you want.
If you want more specific answers, please attach a simple example demonstrating your problem.
Message 2 of 10
(6,096 Views)
For example, I am getting the whole settings as one cluster, and I want to check each sub-cluster for changes compared to the old settings (which means which instrument I should update.)
Message 3 of 10
(6,066 Views)
Sounds like you need to right click on the Equals node and choose Comparison Mode > Compare Elements.
But the picture doesn't really show much at all...
GCentral
Message 4 of 10
(6,061 Views)
Why would an image of a front panel explain the problem???
Message 5 of 10
(6,056 Views)
This what i am getting:
(code-1, front panel result-2)
and I want to compare only the clusters (so get only 4 Boolean elements)
Message 6 of 10
(6,052 Views)
Can you explain what that even means?
Message 7 of 10
(6,045 Views)
Accepted by PokiBono5
That is a day-dream.
Best you can do is check the aggregates and if not equal break out each sub-cluster and compare aggregates on each.
Ben
Message 8 of 10
(6,041 Views)
By unbundling each element and then comparing at the levels you care about, you can get what I think you're describing...
GCentral
Message 9 of 10
(6,031 Views)
Updating Media
I just had the same problem for dynamic cluster length and found out that you can do it with OpenG's Cluster to Array of VData__ogtk.vi
Message 10 of 10
(4,577 Views)
