convert from hexadecimal to decimal
I've recently started working with hexadecimal data. I want to convert a 2 byte hexadecimal string to a decimal number, but the VI which I expect to do that is not quite working out. You can see it attached for an example of what I mean. Any suggestions?
Message 1 of 11
(9,495 Views)
Accepted by greggers89
Hi greg,
this has been asked so many times before: You have to be sure about the representation of your data.
Easiest would be a typecast:
Message 2 of 11
(9,485 Views)
Thank you so so much!
Message 3 of 11
(9,478 Views)
Hey!! Could somebody help me?? I have an labview 2009 and it would be nice if somebody could convert these files (version 4.0.1)  for me! Thx
Message 4 of 11
(9,454 Views)
ohh i just forgot the file 🙂
Message 5 of 11
(9,451 Views)
A better place for your post is the Version Conversion board.
Message 6 of 11
(9,446 Views)
Sorry and thx for the tip
Message 7 of 11
(9,441 Views)
I need to convert a hexadecimal output to a decimal number like 200 for C8. Using hexa to decimal is not working for this purpose. So kindly please help
Message 8 of 11
(9,258 Views)
What are your data types (U8?  String?  I32?) that you are converting from and to?  And be very specific about what you have in your example.  Is "C8" two ASCII characters 'C' and '8' or is it binary C8 with a string data type?
Message 9 of 11
(9,255 Views)
When you convert a decimal to hexadecimal 200 corresponds to C8 that much only I know, using the converter available in internet, decimal number 200 corresponds to C8 in hexadecimal. So i thik you understand the type,
Message 10 of 11
(9,240 Views)
