crystal reports
Hi Marco_Ge,
I've tried to run, and I have too problems....
I need an SQL Database.I set up the connection, but informs me the error of nonexistence of the report to open
Message 11 of 34
(2,737 Views)
Yes it is necessary a Database connection!
I did not put in my example since the question was focused on the viewer.
Try to swap the OpenReport method and the LogOnServerEx method.
I used connection strings (generated through an .udl file) to store the connection parameters.
bye
Message 12 of 34
(2,731 Views)
I've tried to modifie the code, but I have the same problem.
The connection string I've used is correct and work fine, but .vi  program presents the same error.
I've installed the CR version in the image.
What's wrong into my code???
Message 13 of 34
(2,722 Views)
The programming flow is correct... I used it .
If the report .rpt opens without error from the main CR application, then I think your problem should be located inside the parameters you pass to LogOnServerEx.
Looking at them, they are different from mine.
First, put 'crdb_ado' that is the name for the CR active-x data objects driver.
Second, verify that the requested inputs are connected wire by wire... look at my connection string and build one by yourself for your specific database (make a Database connection and then extract the connection string) from an .udl file. (see bottom (*) ).
Keep the wirings to the LogOnServerEx method as in the original example.
Note(*): Create an empty file and change extension to .udl to retrieve connection string.
Open it and from Providers tab select your DB provider (Oracle or others).
In the connection TAB you'll se your database name inside "Data Source Name " control.
Set other information such as Name, Password and database table name.
Click "Check connection" to see if it is OK.
At the end, click OK the window closes and you have saved and configured your .udl.
Now open it with a text editor and you will find the connection string.
Message 14 of 34
(2,715 Views)
One more: An error wire is missing between the ReportSource and Refresh methods; then put error probes at each node to see where the error begins to propagate.
Message 15 of 34
(2,708 Views)
The parameters  to  your LogOnServerEx and mine are different (It's possible that I have a problem with the CRAXDRT??. The vi runs ok).
All the steps to build and .udl file are correct and I made it like you.
Could send me the code with the LogOnServerEx you indicated on the image to see if I have a problem with the property node automatically detects in my .vi?.
I dispose of several facilities since development CR reports in several versions for old customers.
Apology for the inconvenience.
Message 16 of 34
(2,703 Views)
For customer side, I used only to install CrystalXIrdc.msi on destination machine.
This provided me the method included.
Message 17 of 34
(2,698 Views)
It works now!!!!!
The only thing is that by linking the name of the database, the report always retrieves one with which it was designed.
Is there any way to tell the source database? (By linking the LonOnServerEx the name of the database, the values do not change. If I Indicates into connection string don't work.).
Thanks!!!!!!!
Message 18 of 34
(2,694 Views)
As far I know, wiring the exact fields to the LogonServerEx method should provide the database connection to the report, so maybe you have to check once again your parameters...
If it works... give a kudos!
Bye
M.
Message 19 of 34
(2,691 Views)
PS Have you checked your connection string generated with your UDL? (Test connection).
Was it working?
Message 20 of 34
(2,690 Views)
