crystal reports
hello Marco_Ge
i need your help,
Can u correct my code or send me ur code CR print!!!
Message 31 of 34
(923 Views)
Marco_ge
I've been working with the code similar to the last discussion, but methods didn't work. Any method was possible to link.
The embedded control works, but when you try to print, the printer button must be press on and demain program present recursivelly the printer set up page.
I'm trying to help Amani but the before code don't work.
Can you link the code cith methods to print?
Message 32 of 34
(906 Views)
This program pop up the print window, but the print properties too.
I've not been able to display the print menu without displaying the printer properties window.
The only thing I have been able to get is to stop the code, since the second time it is printed, only the printer properties window appears, but not the print menu.
Message 33 of 34
(903 Views)
In the attached VI, your error out is not wired for the "print" indicator, and you are not handling your errors. To better see the issues you're experiencing, can you attach a Simple Error Handler to the error out of the Close Reference VI? Then post the errors if they occur.
Message 34 of 34
(878 Views)
