digits of precision limit to 3 significant digits
there is no other solution except this?
Message 21 of 23
(1,140 Views)
Hi Susanne,
well, to write numeric values to the Excel sheets is the solution.
Writing text instead of numeric values is just wrong…
Message 22 of 23
(1,129 Views)
Accepted by Susanne1709
I found out where the problem was. The value I needed with 3 decimal places was located before writing in the database. There was a separate VI which collects all data from the sensor and convert the number with the function "number to fractional string"  - in this VI the needed value was located - and makes then a concatenate string of ALL collected paramaters of the sensor. If I would have changed that it would have taken weeks for me because I must have changed loads of VIs and logic. Never ever 😉 I changed the precision of the number to fractional string, adapted the database and test it. And it is working - yeeaaahhh Smiley Happy
Message 23 of 23
(1,091 Views)
