divide
how can i generate such numbers where the two number's remainder is 0?always like 4/2 6/3 8/4
(4,947 Views)
I would generate two random numbers and then multiply them.  Take either of the original numbers and the multiplication result.
(4,942 Views)
Integers only? If you want to deal with floats you will have to decide what zero is. Is 0.00000 zero? Well how about 0.000001, is that zero? The issue is that integers are exact, floats are approximations.
Why are you needing this?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,923 Views)
(4,894 Views)
only integers.
I want to make the lumosity raindrops.operations must be very simpleNévtelen.jpg
(4,881 Views)
Next time please use a reasonable thread subject. "divide" does not mean anything useful. Thanks!
Please attach the actual VI instead of pictures. What is inside the other case? What is the purpose of the FOR loop? (You seem to sue the FOR loop as a glorified sequence frame). Where do the hidden wires actually go? What is the point of the linefeeds? What is the point of the two waits, they seem to run in parallel? What is the point of the sequence structure? Seems pointless. Do you really need a formatted width of 10 characters for a two-digit number?
Can you explain what you mean by lumosity raindrops and how it relates to your question?
Also make sure to answer my questions form the other thread.
(4,847 Views)
(4,784 Views)
