06-26-2013 03:45 AM
Florian and Paul,
i tested several combinations now with bitness and languages (english and german) but i cannot reproduce the issue.
What language are you running for Windows and LV?
Norbert
06-26-2013 03:48 AM
Hi.
I run the german versions of both LV and Win7.
Regards Florian
06-26-2013 04:05 AM
Odd, that combination works well here even with LV 2011 SP1 installed in parallel.....
But for testing, you might try to change e.g. regional settings.
Is the Windows a standard edition or is it modified by the companies IT department?
Norbert
06-26-2013 05:24 AM
Thanks for the tip. I'll try that once I feel save (have to release sth. next week).
Windows is a standard edition.
Regards Florian
06-26-2013 06:41 AM
Another thing which comes to mind:
What happens if you reset the LabVIEW.ini?
Norbert
06-26-2013 07:27 AM
I have two development systems with this same behavior. One is running a "corporate" version of Windows 7 Enterprise and the other is running a generic Windows 7 pro.
I also tried resetting the LV.ini file. No effect.
06-26-2013 07:36 AM
If this means anything, I have been getting a windows popup that says "There was a problem sending the command to the program" when I try to open a program in LV2012. No explanation. Otherwis LV is running fine on both machines. This behavior just started as well. It could very well have started the same time I started seeing the drag and drop bug.
06-26-2013 07:37 AM
Florian and Paul,
do you have any specific toolkits/modules or non-NI components installed to LV?
What package of LV are you using (Base/Full/Pro)?
Norbert
06-26-2013 08:34 AM
I have seen OS behavior where drag and drop does not work if an application is run with administrator privileges.
06-26-2013 09:10 AM - edited 06-26-2013 09:12 AM
This fixed my drag and drop problem but creates another. I need admin privileges to write Excel files.
This is a bug.
