Showing results forĀ
Search instead forĀ
Did you mean:Ā
edit combo box array
I am trying to add a value to a specific combo box in a 2d array.
lets say i have a 2d array of combo boxes, how can i add a value to the combo box in row 3 and colomn 4?
Thank.
Message 1 of 31
(4,906 Views)
Hi Alvarion_…,
what do you mean with "add a value to the combo box in row 3 and colomn 4"? Do you want to change the value? Remember you can only define one item list! You can“t have in one element other entires than in another one.
Mike
Message 2 of 31
(4,901 Views)
Yes Mike the second i got the mail indicating the replay from ni was the second i understood that issu....is there another way to have a couple of  combo boxes or rings  with diffrent lists?
Message 3 of 31
(4,897 Views)
Hi Alvarion_…,
what is the purpose behind this? What do you want to make with the different combobox items?
Mike
Message 4 of 31
(4,893 Views)
Hey,
I have an ini file with diffrent tests and every test has a diffrent settings, for example:
[HO type_Intra ASN Handover]
Type=INI VI
Delay between H.O=5,2
Trafic type=Smartbits,Ping
Number of Handover=xxx
[HO type_Inter ASN Handover]
Type=INI VI
Deleay between H.O=5,2
The idea is that for example delay between handovers is a combo box parameter with values of 5,2 and trafic type is also a combo box parameter but with values smartbit or ping and the number of handovers is a regular string how can i diplay those parameter for the user ? there can be more then 3 parameter...is there a solution ?
Message 5 of 31
(4,890 Views)
Hi Alvarion_…,
you can add all your values to one combobox, and depending on the selection you can transform the 5.2 string to a number. Why do you need different combo boxes?
Mike
Message 6 of 31
(4,888 Views)
Its one solution but i dont want to create a situation in which the user can choose a "bad" parameter for a value, in your solution the user will be able to insert 5 as an input in the traffic type box and this is a problem, i need the user to have only the "right" parameters in  his choise.
Message 7 of 31
(4,883 Views)
Hi Alvarion_…,
i understand, a solution could be to change this values from step to step. Use a property node and select "Strings[]". You can connect an array with all values you currently want to present to the user and which can than be selected.
Mike
Message 8 of 31
(4,879 Views)
But the user will see them all as a table...he will not see each parameter is a diffrent time.
see the picture.
Message 9 of 31
(4,873 Views)
Hi Alvarion_…,
why do you need your combobox in an array? You can use three single comboboxes.
Mike
Message 10 of 31
(4,862 Views)
