error 4 at write file +{I16} at labview 7.1
I make something like these in 8.6.1
but in Labview 7.1 I cant make it x(
could any1 upload a vi that change the name of the file and continuos writing the file for each 5 hours??
Message 11 of 40
(1,890 Views)
Hi EduU,
here's an example based on my last message... I only made the general structure, you have to fill in missing parts Smiley Wink
Message 12 of 40
(1,888 Views)
Accepted by EduU
Attached a 7.1 example which writes to a file every 5 hours.
Christian
Message 13 of 40
(1,880 Views)
Hey Christian
Thanks for the example
but I'm having some problems here
I'm using the write [I16] file
and when the time have passed, like 5 hours
the program close the file
and when will start the other one
i receive an error:
Error1 : Occurred at Write File +[I16]: Write file
Possible reason: An input parameter is invalid
I make equal yours, i will upload the VI so if you can
take a look and see what I'm doing wrong! =/
I put the value to compare as 10 only to make the test faster.
Message 14 of 40
(1,876 Views)
You will need to change the loop tunnels of the file reference to shift registers.
Christian
Message 15 of 40
(1,874 Views)
ohh really thanks Chris!
Now it works!
Message Edited by EduU on 12-11-2009 09:09 AM
Message 16 of 40
(1,870 Views)
Hey Christian, Now i have one problem when I'm trying to read the files I splited.
The first file, I can read it perfect, but the second and the others I receive the same error as I was receiving at write, but at Read File +[I16]
I tryed to change the loop tunel to shift register, but still don't work.
Any other clue to give me?
Message 17 of 40
(1,855 Views)
Hi EduU,
how are you reading your files? How can there be an EOF error on start of reading?
Clue: Select the correct file for reading Smiley Wink
Show your vi!
Message Edited by GerdW on 12-11-2009 05:17 PM
Message 18 of 40
(1,851 Views)
well I'm uploading the VI
and I'm selecting the correct file for reading
always when I execute this program I have to select which file will be read!
Message 19 of 40
(1,847 Views)
Hi EduU,
apart from that horrible block diagram:
You only open one file and read from it continuously. I thought you had splitted your data into several files and now you read from one file only?
Please cleanup your VIs before posting...
Message 20 of 40
(1,844 Views)
