find the x and y coordinates closest to zero on a circle
Hi, I have a program that has created a 2D array that generates a circle. I need to find the index of the array that is closest to 0,0 (X,Y).
In the picture attached, I can see manually that the ellement I am looking for is 17 but I need labview to calculate the answer for me. Can anyone help?
(3,049 Views)
Accepted by beam7
Fairly straightforward
Use X[] and Y[] as Real and Imaginary Rho is distance to origin.   find the minimum
(3,034 Views)
Accepted by beam7
Hi beam,
calculate the distance between your points and origin (0, 0). Find the minimum of all distances…
See this simple math on your array data:
(3,032 Views)
(3,021 Views)
Thanks GerdW
(3,018 Views)
