generate two different number
Message 11 of 19
(2,048 Views)
szabolcs,
That will not work per the requirements.  You can still get random numbers so that the top number is 1 and the bottom is 19 (playing the worst case.
Here is the solution I am recommending.
Message 12 of 19
(2,033 Views)
already made it.THX
Message 13 of 19
(2,016 Views)
That will not guarantee that one number is greater than the other.  Although unlikely, it is possible that both values could be the same.
Lynn
Message 14 of 19
(1,995 Views)
i expressed myself wrong .It's enough that the value isnt negative
Message 15 of 19
(1,975 Views)
how can i generate such numbers where the two number's remainder is 0?always
Message 16 of 19
(1,953 Views)
I would generate two random numbers and then multiply them.  Take either of the original numbers and the multiplication result.
Message 17 of 19
(1,923 Views)
Unless you are dealing with integers, you are entering dangerous territory here.
So far you said that the numbers should be positive. What is the upper limit? Are fractional numbers allowed? Are the random number supposed to have a uniform probability distribution?
Message 18 of 19
(1,892 Views)
Apparently continued here. Please keep it all in one place!
Message 19 of 19
(1,872 Views)
