how I can use EVENT structure with read VISA functions ?
@smithd wrote:
Basically this (https://decibel.ni.com/content/docs/DOC-2431) or this (https://decibel.ni.com/content/docs/DOC-30005) except with visa instead of the DAQmx VIs or the event structure.
Edit: ^^his is better
the webpages you mentioned doesn't work !!
error is : not found.
Message 11 of 12
(1,097 Views)
The ')' got added to the link.  Just delete those in the address bar and it will work.
Message 12 of 12
(1,092 Views)
