how to do every 600 seconds to execute For loop?
Luis_AM3C, please tell me the Rube Goldberg is on purpose...
Message 11 of 40
(1,300 Views)
HI,
this is my vi
i want to delay 45s to execute for loop at first
then when it finished done
every 600s to execute this for loop
i try some methods,but can't solve 😞
Message 12 of 40
(1,285 Views)
Hi crossrulz,
¿Para qué hacerlo fácil si lo podemos hacer difícil?
Google Translator: Why do it easy if you can make it difficult?
Try adding a stop button without abort VI, and tell me which one is the Rube Goldberg Machine? or wanna wait 10 min for stop?
600 = 2*2*2*3*5*5
45 = 3*3*9
GCD = 3*5 = 15 sec
3 cycles = 45 sec
40 cycles = 600 sec
I added the feedback node because I just learn to use them, after reading that work as a delay z ^ -1. And is the correct method instead of a shift register.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 13 of 40
(1,280 Views)
Still yours.  Since you are already using an event structure, set the event wait to 600 seconds and add an event for the stop button.  No waiting for the stop at all!
Message 14 of 40
(1,274 Views)
I know there are Pros and Cons between the Shift register and the feedback node but where is given feedback node is correct compared to shift register. You can share the link that would be helpful.
Message 15 of 40
(1,267 Views)
Is this the sequence?
1.) Wait 45 seconds
2.) Start the FOR loop
3.) Iterate the FOR loop every 600 seconds?
or...
1.) Start the FOR loop
2.) i=0, iterate after 45 seconds
3.) i>0, iterate after 600 seconds
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 16 of 40
(1,257 Views)
They work the same.  There really is no difference except for the fact that feedback nodes do not have to be on structure edges.  That could clean up some wiring as long as the value of the saved data is not needed outside of the loop.
Message 17 of 40
(1,256 Views)
Before understand feedback node (until yesterday), i always used shift register for use the previous value iteration, wiring the shift register trougth all my cases, today i see that if i only use the previous value at one case i should use feedback node instance of shift register, because is less wire and the diagram is more clear. Because feedback node keep more clear the diagram i call it correct, i dont sure about performace, but is easy to test (i test it, shift register is more fast :S). Thank you for write, i am learning all days a little.
Best Regards,
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 18 of 40
(1,251 Views)
Thanks crossrulz, I already worked with feedback node but he said feedback node is correct thats why asked is there any benchmarks done to prove that. But actually when the number of feedback nodes increases it really messup compared to shift registers.
Message 19 of 40
(1,250 Views)
There are quite a few difference between feedback nodes and shift registers.
Shift registers:
always need a loop structure
right left side can be resized to get sucessively older history values.
Feedback nodes:
Allow global initialization
have an optional "enable" terminal
Don't need a loop structure (great for action engines)
Allow only one history value (selectable delay, check properties...configuration)
Message 20 of 40
(1,242 Views)
