how to export more than 100 points from waveform to excel
@dan190 wrote:
Hey Jeff, and other Labview individuals 🙂
I am currently stuck&confused. The TDMS does not give me what I want.
So basically, for testing purposes, I have a TDMS and a "Export Data to Excel". So every test run, I get two spreadsheets.
The "Export Data" function gives me the following
This is what I want, except that it only gives me the past 100 points. I want everything, from start to STOP.
Here is what I am getting with the TDMS
Quite different. Not really what I want.
Am I supposed to modify the TDMS differently? Maybe use different functions?
Kindly let me know, thank you.
Thats cover data-  look at the next sheet in the workbookSmiley Wink
Message 11 of 12
(731 Views)
Oh wow..... *embarrassed*
Thank you!
Message 12 of 12
(723 Views)
