how to operate a set of commmands one by one using seqwence loop
when I'am communicating with a motor, I used the attached VI but it will work only when bulb is on. So how can I execute the same as bulb is on off state. please reply
Message 1 of 21
(3,442 Views)
If your delay, read & write states remain the same, you could do this.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 21
(3,437 Views)
the first blue row, how can I creat it. can you please tell me. And my motor will take a command , the next command will happen only after the first command reply comes. Is this VI will work for me. If you send me a VI it will be very helpful to me.
Message 3 of 21
(3,429 Views)
Thats an array constant.
You can save the file on to your computer as (.png) and drag and drop it on to your block diagram.
Message 4 of 21
(3,425 Views)
but I put array constant to my program, but its not coming as you fed. So can you help me in creating that row I expect your reply
Message 5 of 21
(3,422 Views)
I put your png file as you told but the VI shows errors as like as I attached . So please help me to overcome this
Message 7 of 21
(3,416 Views)
If you try to run the vi, the error listing window will pop-up. Double click on the first item in the list and it will take you to the error area. There you can find that YOU have added an array constant. Please remove that and it should work just fine.
Message 8 of 21
(3,412 Views)
But how can I convert each number to its corresponding ascii command. can you please help me.
Message 9 of 21
(3,386 Views)
in the given link it's not telling that using array constant each value will take one by one. And I need every value to be converted to ascii value which ishown in my Vi. So if you help and correct my confucsion its helpful
Message 10 of 21
(3,384 Views)
