insert calender in labview 8
I have a text control for accepting a date. I would like to place a small button at the end of it, clicking upon which, a calender should appear and the user should be able to select the date from the calender, and the calender should go away. The nearest I got to wasthis:
https://forums.ni.com/t5/Example-Code/Using-the-Month-Calendar-NET-Control-in-LabVIEW/ta-p/3996273
but the calender here is very large. I dont want that.
Any help?
Thanks!
(2,917 Views)
Accepted by pcs82
Hi pcs,
have you tried the timestamp control available in LabVIEW (numerics palette)?
(2,913 Views)
Hello Gerd,
Thats exactly what I wanted! Thanks a lot!!
(2,897 Views)
