insert calender in labview 8
I have a text control for accepting a date. I would like to place a small button at the end of it, clicking upon which, a calender should appear and the user should be able to select the date from the calender, and the calender should go away. The nearest I got to wasthis:
https://forums.ni.com/t5/Example-Code/Using-the-Month-Calendar-NET-Control-in-LabVIEW/ta-p/3996273
but the calender here is very large. I dont want that.
Any help?
Thanks!
(2,906 Views)
Accepted by topic author pcs82
Hi pcs,
have you tried the timestamp control available in LabVIEW (numerics palette)?
(2,902 Views)
Hello Gerd,
Thats exactly what I wanted! Thanks a lot!!
(2,886 Views)
