labview
i think the problem is with th subvi write into spreedsheet
Message 11 of 51
(3,597 Views)
Oh yes can you please send me the sub vi write into spreedsheet
Message 12 of 51
(3,594 Views)
Try this one. The file should appear in the same directory as the VI.
The reason your write to spreadsheet file has a cross through it is because you;re using LV 2015. They updated the VI for that so the one in my VI is an older version. Should still work though.
Daniel Harryman MEng
CLA, CPI
Message 13 of 51
(3,590 Views)
this is what is written for me about the vi write into spreedsheet file:
VI is obsolete. Instead, use the following VI:
vi.lib \ Utility \ file.llb \ Write Delimited Spreadsheet.vi.
Message 14 of 51
(3,579 Views)
I only have LV 2014 on my Laptop so I can't make a VI with the new write to spreadsheet file you talk about. Either way the VI should still run... The VI i posted in my last post should still work. If not just replace the write to spreadhseet subVI with the new one in the directory you posted.
CLA, CPI
Message 15 of 51
(3,575 Views)
Maroua,
     Why do you persist (despite pleas and warnings from your other posts) in "Bad Behavior" on the LabVIEW Forums?
  • When Posting, ask a Question as the Subject, or State a Problem.  Subjects such as "LabVIEW" (this post), "u", or "d" (two of your earlier posts) are not helpful.
  • When asking for help with your code, post your code (the VI, not a picture of part of the code).
  • When someone tries to give you some help, show that you are making an effort to listen and incorporate their help, don't just keep asking the same question in another form.
     The purpose of this Forum is to provide specific help for specific LabVIEW problems.  The purpose is not "Do My Homework For Me".  It is also not "Teach me LabVIEW" -- for that, the upper right corner of the first page of the Forum has the following:
Clicking the first Entry and spending a little of your time (instead of ours) would probably have answered the question you are asking (and re-asking) in this post.
Message 16 of 51
(3,556 Views)
Ok mr Bob schor
First of all i post only a picture so that the code won t be confusing and big and to precise where exactly i have a problem ,Moreover ,there were so many times where i posted  codes not pictures !
Message 17 of 51
(3,546 Views)
This post has a name  "labview"it s not "a" or" d" as you told and sorry if sometimes i forgetted to name correctly my posts
Message 18 of 51
(3,540 Views)
And for sure thanks for the references you posted
Message 19 of 51
(3,536 Views)
for the svi,I used the new xrite into spreedsheet and i think it works but there s a problem with excel because when i try to open my xl File it can t open but before execution it opens normally
Message 20 of 51
(3,530 Views)
