monitoring unknown tank level and control
tnx a lot GerdW
but I couldnt find num to boolean block. can u address it please?
and can u get me a picture about situation of set %b too?
Message 21 of 29
(1,833 Views)
Hi behzad,
1) Look in the boolean functions palette for any function dealing with booleans. And have the context help window open…
2) To change properties of a control you right-click it, open it's properties dialog, switch to the display format tab and set it's format…
These are basics. Please do all those free online courses offered by NI!
Message 22 of 29
(1,832 Views)
tnx Gerdw, I searched but there is no integer to boolean convertor Icon over there.
I want use 20 tank, then if I enter number 3, all of them hidden except 3 tank. r u sure that is possible? how (pleas clearly)? I cant do with these solutions.
Message 23 of 29
(1,827 Views)
Hi behzad,
when you can't count upto 20 you definitely should go through LabVIEW basics courses! 😄
See this inspiration:
Message 24 of 29
(1,823 Views)
tnx a lot,
I new student to leanrning Labview. I cant found TF block too! 😞
can u say me how seperate use of each bit?
Message 25 of 29
(1,818 Views)
Hi behzad,
for the 3rd time: go through all those FREE ONLINE LabVIEW courses offered by NI!
"TF block" is a boolean array indicator, created by right-clicking the FOR loop output tunnel…
How to "separate each bit" I have told you before: IndexArray!
Message 26 of 29
(1,812 Views)
HI GerdW
I didnt know anything about that kind of courses;
your help was really good. tnx.
TF there is not in my program. I used IndexArray. but I need all 20 bit of boolean array at the same time. IndexArray cant seperate all of them and just get me one bit.
Message 27 of 29
(1,810 Views)
Hi behzad,
now you know…
Use just one IndexArray function! Did I mention this before?
Message 28 of 29
(1,807 Views)
OK, tns a lot.
I really appeciate GerdW for his great help.
Message 29 of 29
(1,805 Views)
