nonlinear curve fitting for a lead acid battery PLZ HELP
I don't think this is correct. I think time is related to the line number and not contained in your data.
To me it seems you have 2D data (which is also easy to fit). E.g. Q(I, t). Can you clarify?
Message 11 of 25
(1,639 Views)
what do u mean by line number?
the relationship is Q= It but our original data contains I and Q so i found t  by Q/I since our fitting formula does not contain I and it should be
Q(T, q,c,k)=(qkcT)/(1-exp(-kT) + c(kT+exp(-kT) - 1))
ill also attach dataset with I but i dun thnk it is needed
Message 12 of 25
(1,636 Views)
So, since x and y (I and t) are linearly related, we get four linear curves, each with a different slope. This cannot be fit to a complicated equation. 😉
There has to be something else! Here's a picture of the 3D data that could be fit if we had a model of Q(I,#).
Message Edited by altenbach on 09-16-2007 12:07 PM
Message 13 of 25
(1,626 Views)
hmm but from the link i sent u earlier they managed to get the curves fitted and found the parameters.And it is a 2D. Q vs t..btw is it possible to attach ur VI ?
Message 14 of 25
(1,621 Views)
U could also refer to the following link for more theory if u have time.
www.solenergi.dk/rapporter/sec-r-12.pdf
especially on page no 49
Thx mate 🙂
Message 15 of 25
(1,609 Views)
sorry about double post but.for now just ignore the dataset i provided i would appreciate if u just assist me in builiding the VI as datasheet i can import later
Message 16 of 25
(1,605 Views)
Here's what I did. I first use the model to simulate some data, the the fit succeeds well. (make sure that X cannot be zero).
(The result is only exact if there is no noise, of course)
Please double-ckeuch the model VI to make sure it is correct.
I still think you are misinterpreting your data.
(LabVIEW 8.0)
Message Edited by altenbach on 09-16-2007 03:36 PM
Message 17 of 25
(1,601 Views)
thx a lot for your great help man.. about the data set ill post a new one but not sure how it will turn out
but now it seems that we would have to change equation from
Q(T, q,c,k)=(qkcT)/(1-exp(-kT) + c(kT+exp(-kT) - 1))    to  ========>>>>  I(T, q,c,k)=(qkc)/(1-exp(-kT) + c(kT+exp(-kT) - 1)) to this i removed the T in numeator
Message 18 of 25
(1,562 Views)
See, NOW things start to make sense. 🙂
Message Edited by altenbach on 09-17-2007 08:11 AM
Message 19 of 25
(1,552 Views)
hehe ya..thx a lot man 😄
i have few other questions as well.. but i would post them later.. is it ok i keep all my questions to this thread?
Message 20 of 25
(1,546 Views)
