01-10-2009 02:22 PM - edited 01-10-2009 02:27 PM
Yes. I have done this many times for documentation purpose. First open the picture you want to paste in paint (or some other picture tools). Copy the picture/picture part, you want to paste in. In the block diagram menu, go to edit and select paste. Then you are done. Work also if you use the "print screen" button (in windows), and then select paste.
Edit: while I was typing Cory came up with the solution. :smileyvery-happy
01-10-2009 02:24 PM
If you just want the image, I wouldnt recommend print screen.
That would paste a picture of your whole current screen, toolbars and everything.
I'd stick to copy/paste
01-10-2009 02:26 PM
01-10-2009 02:29 PM
I'm using Windows Vista. That may be the difference.
Are you using XP?
Yes, this is literally what I did.
I opened up the folder that had pictures.
The files' icons are being displayed as "large icons".
I right click on an image >> copy.
Then went to the block diagram and 'ctr + v'
01-10-2009 02:33 PM
yup, that's the difference. I'm in XP. It's unfortunate, because I would prefer to be able to create a picture constant. I can label a picture constant, but not a picture decoration. oh well.
thanks again.
01-10-2009 02:38 PM
You can label whatever you want on the block diagram.
Just double click on some empty space on the block diagram and a free-label will pop up.
Then type whatever you want to label the image, and drag the label where you want it.
01-10-2009 02:41 PM
01-10-2009 02:43 PM
Root Canal wrote:
free labels are like confetti on a windy day
I may have to quote that some time....
01-10-2009 08:17 PM
01-10-2009 08:41 PM - edited 01-10-2009 08:44 PM
Root Canal and Cory,
if you use the diagram cleanup tool, you'll also learn quickly that pictures and decorations are also confetti :D. And since the group command doesn't work... 😞
Here is a small challenge for you : there is something wrong in the BD image below (it's a LabVIEW bug, not yet reported). Could you spot the problem ? 😉
