place an image on the block diagram
Accepted by Root_Canal
Yes. I have done this many times for documentation purpose. First open the picture you want to paste in  paint (or some other picture tools). Copy the picture/picture partyou want to paste in. In  the  block diagram menu, go to edit and select paste. Then you are done. Work also if you use the "print screen" button (in windows), and then select paste
Edit: while I was typing Cory came up with the solution. :smileyvery-happy
Message Edited by t06afre on 01-10-2009 09:27 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 11 of 35
(2,961 Views)
If you just want the image, I wouldnt recommend print screen.
That would paste a picture of your whole current screen, toolbars and everything.
I'd stick to copy/paste
Cory K
Message 12 of 35
(2,959 Views)
Corey- so you just right clicked on a file in windows and selected copy, then went to your block diagram and pasted? did you use crtl+V to paste or the drop down edit menu? I couldn't get it to work that way.
global variables make robots angry
Message 13 of 35
(2,956 Views)
I'm using Windows Vista. That may be the difference.
Are you using XP?
Yes, this is literally what I did.
I opened up the folder that had pictures.
The files' icons are being displayed as "large icons".
I right click on an image >> copy.
Then went to the block diagram and 'ctr + v'
Cory K
Message 14 of 35
(2,953 Views)
yup, that's the difference. I'm in XP. It's unfortunate, because I would prefer to be able to create a picture constant. I can label a picture constant, but not a picture decoration. oh well.
thanks again.
Message 15 of 35
(2,949 Views)
You can label whatever you want on the block diagram.
Just double click on some empty space on the block diagram and a free-label will pop up.
Then type whatever you want to label the image, and drag the label where you want it.
Cory K
Message 16 of 35
(2,939 Views)
If you use the diagram cleanup tool in version 8.6, you learn quickly that free labels are like confetti on a windy day. Smiley Tongue
Message 17 of 35
(2,938 Views)
I may have to quote that some time....
Cory K
Message 18 of 35
(2,935 Views)
In don't see any difficult step when adding a picture to the BD : even opening the file is not required !.. the most straightforward method is to drag the picture from the file list in Windows directly onto the diagram. This works with jpg, gif, bmp and png pictures, not with tif images.
Chilly Charly    (aka CC)
Message 19 of 35
(2,892 Views)
Root Canal and Cory,
if you use the diagram cleanup tool, you'll also learn quickly that pictures and decorations are also confetti :D. And since the group command doesn't work... 😞
Here is a small challenge for you : there is something wrong in the BD image below (it's a LabVIEW bug, not yet reported). Could you spot the problem ? 😉
Message Edité par chilly charly le 01-11-2009 03:44 AM
Message 20 of 35
(2,890 Views)
