place the cursor in certain indicator
Yeah, but what I find irritating in this method is that the frame is visible. Can I make it transparent ?
Message 11 of 26
(1,406 Views)
Yes, you can.
Just rt-click with the Coloring tool (with more concentration) on the Str Ctl border & then the color pallette will pop-up. Then you can press space/tab key to make the border as transparent.
But I think this work only for a Str Ctl took from the Classic pallette, not with the modern Str Ctl.
Message Edited by parthabe on 08-03-2009 03:29 AM
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 26
(1,403 Views)
I dont know If that is possible.
Message Edited by muks on 08-03-2009 01:59 PM
Message Edited by muks on 08-03-2009 02:02 PM
Message 13 of 26
(1,401 Views)
What happened Muks... ?!
Message 14 of 26
(1,397 Views)
I suppose that this method doesn't work.  The normal menu pops up. Check out the attached picture.
Message 15 of 26
(1,393 Views)
doesn't work with both string control from the Classic pallette and one from the normal one...
Message 16 of 26
(1,396 Views)
Did you try it out with the COLORING tool?
Message 17 of 26
(1,395 Views)
It is a meticulous thing to do. You need to be slow & steady.
Message 18 of 26
(1,390 Views)
If you are asking about my edited message, I had mentioned "I suppose it is not possible" After seeing your nice suggestion:smileywink: I thought my message would be misleading. Hence............
Message Edited by muks on 08-03-2009 02:14 PM
Message 19 of 26
(1,388 Views)
hm..strange...doesn't work..by COLORING tool do u mean this one (pic attached)? In case yes, I was really careful but seems to me that it doesn't do the job.
Message 20 of 26
(1,384 Views)
