place the cursor in certain indicator
No. the one down to it will do the job.
- Partha ( CLD until Oct 2027 🙂 )
Message 21 of 26
(814 Views)
I am afraid this is not the thing I want. Because using this method you can make the border of the control transparent not the frame resulting from the key focus feature.
Message 22 of 26
(812 Views)
Then, I think you should go for the Str Ctl from the Systems control pallette.
I remember long back I did something on your lines, where the cursor alone will blink within the control with its Keyfocus set to true, but there would not be any border around it.
Message 23 of 26
(806 Views)
Message 24 of 26
(790 Views)
Did you mtry out with the Str Ctl available in the Systems pallette. I m sure it works for Keyfocus w/o the black border.
Message 25 of 26
(772 Views)
Here you go
Did that make sense?
Message 26 of 26
(757 Views)
