processing the array elements
Sorry,If my question is not clear.I have an input array(hexadecimal string array).It is representing digital data,so each array index represent 1 bit.I just want to take the first 8 elements and represent in the form of hex in the first index of the output array.Then take the next 8 inputs and after conversion display it in the next index of the output array.
But when I tried I got the output as shown in the attachment.
Message 11 of 42
(3,396 Views)
I just saw that your input is a string, so use the conversion you had in the vi you posted before.
Christian
Message 12 of 42
(3,390 Views)
Sounds like this might work for you as well.  No need to convert strings into numbers.
Message 13 of 42
(3,380 Views)
You can't keep Type Cast man out of this party.
Message 14 of 42
(3,369 Views)
Accepted by topic author josy
Is this want you wanted?
Message 15 of 42
(3,364 Views)
WOW!!great.varities of answers.ThanksSmiley Happy
Message 16 of 42
(3,352 Views)
      Let me add one more question.If we are getting string elements on each iteration,then how will we form it into an array with the first iterated element into the first array index of the output array,second iterated element on the second index of the output array and so on....
Message 17 of 42
(3,327 Views)
It kind of depends on your architecture.  Are you getting a bunch of elements and then pass the array on when you are done collecting?  Or are you just building the array for GUI purposes?
Message 18 of 42
(3,323 Views)
        Iam getting the value one by one.And using that I build an array,But the entire elements displayed in the first index of the array.But I want to display it in index one by one.(that is corresponding indices.)
Message 19 of 42
(3,311 Views)
I'm still not sure if I'm understanding you properly.  But it sounds like you could do it with a simple shift register and build array.  I used a feedback node instead of a shift register in the example below.
Message 20 of 42
(3,298 Views)
